If I wanted to build a dual driver Jack 15, can I upscale the dual 12 plans?
Or would it be easier to just use the single 15 plan and simply make it a double from there, extending sides and back to match the doubled dimensions?
Thanks
Dual Jack 15
Re: Dual Jack 15
Build two Jack 15, stack them. A 2x15 Jack would be too large to manage. For that matter build one J15 and use it before building a second. My J15 is the world's largest paper weight, as I've only had one gig where I used it. That was outdoors. Indoors my single J12 is plenty.
Re: Dual Jack 15
Thanks, I just bought your Simplexx 15 plans, will buy the jack 15 plans as well
