T48 driver = Ultimax UM15-22 ?
nightvision
#1 Post by nightvision »
Will the Ultimax UM15-22 work in the T48? The driver QTS is at 0.71 which is higher than the plan calls for. The other requirements seem within spec. I already have an extra driver on hand.
Vd 1548cc
FS 48.4 Hz
Xmax 19.4mm
Also, I recently used this driver in the THTLP, and it's a big driver, so not sure if it will physically fit in the T48.
Thanks for your help.
Re: T48 driver = Ultimax UM15-22 ?
It will work, not as well as the 3015LF, and it might not fit. Fs, BTW, is 28.4.
nightvision
#3 Post by nightvision »
Thanks Bill.
