So I regularly go out doing playback gigs as a duo in very small clubs and pubs here in the UK where a couple of small active 8" speakers are all that's required both size and SPL wise, and I was considering trying to build a higher quality system to replace the above including a small sub to achieve a nice rounded low end.
So I was thinking that a Tuba 18 or Tall Autotuba but which and why? I probably only need it to play down to about 45/50Hz and the T18 looks promising for that. Any response curves or predicted response curves for a T18 not placed in a corner?
Super compact tuba for very small gigs - T18 or AT?
Re: Super compact tuba for very small gigs - T18 or AT?
There are no charts for T18 other than with corner placement as that's the preferred placement, with wall placement an option only if that's the only option. Because 75% of the system power demands are in the sub passband an 8" loaded sub won't keep up with a pair of 8" loaded mains, or SLA Pro, which is what you should be looking at for mains.
Yes I respect that, what would you expect the response of the T18 at 50Hz or thereabouts to drop to when wall loaded?
6dB less than in a corner. Away from a wall 12dB less. Then there's the matter of a driver able to handle the job. They're out there, but they're not cheap.
