Crossover in an Omni 10.5 (crossfire)
neepheid
#1 Post by neepheid »
I am the owner of an Omni 10.5 (crossfire) that someone else assembled. Sorry if this is off limits, but I'm looking for some advice. The large resistor which connects to the tweeters broke (at the legs), I guess due to vibration as it wasn't glued down or anything.
My question is - is there anything else missing? I don't have the plans as I'm not the original builder. If I need to buy the plan or contribute in some way, that's fine, just let me know.
My amp went into protection mode during a gig on Saturday night (last song, thankfully, and was able to struggle on with whatever was coming out of the PA) - if the resistor let go while the amp was on, could this annoy an amp into protecting itself?
I've ordered a replacement based upon the markings on the broken one (3.9 ohm, 20W, 5% tolerance).
Hope you can help.
Re: Crossover in an Omni 10.5 (crossfire)
That resistor prevents high frequency oscillation with inexpensive amps. When it broke off the only result would have been the tweeters shutting down. That wouldn't cause amp shut down.
neepheid
#3 Post by neepheid »
Thanks for the reply. I'll repair the cab anyway and do some testing. Unfortunately, it means I'll have to look elsewhere for my smoking gun, and if I don't find one, I'll have to look elsewhere for an amp I can trust - I can't gig what I can't trust :(
