Throat Sheath Brace Size
fender3x
#1 Post by fender3x »
I realized that I have two circles with a 5 1/8" radius left over after cutting out my woofer spacers. The throat sheath braces are to be cut from a 5" radius circles. Is 5 1/8" close enough, or should I trim them?
1 x DR250
1 x T39
1 x Omni 10
Re: Throat Sheath Brace Size
Close enough, but the length and height will have to be adjusted to fit.
fender3x
#3 Post by fender3x »
Great! Thanks, Bill!
1 x DR250
1 x T39
1 x Omni 10
fender3x
#4 Post by fender3x »
In an abundance of caution, I made a paper sheath brace using a 5" radius and a 5.125" radius. You can see that the 5.125 radius is slightly flatter...but at it's most profound, the difference is about 1/32". I generally think I am doing well when my errors are in this range ;-)
1 x DR250
1 x T39
1 x Omni 10
