Full range subwoofer? I don't know enough about driver design to know if the double magnetic gap this has will add some value or performance?
https://www.parts-express.com/Epique-E1 ... quantity=1
Epique E150HE-44 5-1/2" DVC MMAG Extended Range Subwoofer
Re: Epique E150HE-44 5-1/2" DVC MMAG Extended Range Subwoofer
It was engineered to produce premium controlled subwoofer performance, while simultaneously achieving a smooth extended high frequency response.
Thanks to its revolutionary MMAG dual gap motor, the motor force is nearly constant even when driven to the limits of its 14 mm Xmax.
Capable of unheard-of excursion for its size while delivering smooth midrange response with low distortion, the E150HE-44 woofer gives you the opportunity to create systems that provide extraordinary accuracy and fidelity.
Vd is 139.7cc. The Vd of an average eight, like the Dayton DCS205-4, is 180cc. The Dayton also has lower Fs. It's not a driver that I'd use.
