Page 1 of 6
OmniTop 12 build
Posted: Tue Jan 24, 2023 7:25 pm
by Fastskiguy
The journey starts! This isn't gonna be fast but hopefully we'll make it all the way
Re: OmniTop 12 build
Posted: Tue Jan 24, 2023 7:34 pm
by Clef's of Bass
layout looks good!
Posted: Tue Jan 24, 2023 10:45 pm
Enjoy your journey!
I have the same earmuffs at work. I like them.
Posted: Wed Jan 25, 2023 5:02 am
by Clef's of Bass
Tom Smit wrote: ↑Tue Jan 24, 2023 10:45 pm
Enjoy your journey!
I use the 3M muffs. Has AM/FM and bluetooth. They get a lot of use during garage/ shop time and yard work.
Posted: Wed Jan 25, 2023 1:32 pm
by Fastskiguy
I was hesitant to share this picture because it will make any flaw completely unacceptable given the equipment I was able to access....but what the heck, I'm a beginner. Main panels are cut!
Posted: Wed Jan 25, 2023 2:42 pm
by Seth
Posted: Wed Jan 25, 2023 4:10 pm
by CarterKraft
Very nice
Posted: Wed Jan 25, 2023 4:45 pm
by jimbo7
Compression drivers or tweeters?
Posted: Wed Jan 25, 2023 7:15 pm
by Fastskiguy
I'm gonna try for that cross firing tweeter array. I made two TLAH and two SLAs so wiring them up should be not terribly different. At least that's the current plan!
Joe
Posted: Fri Jan 27, 2023 10:09 pm
by Fastskiguy
Is the jigsaw the thing to use cutting out the baffle? Mine tore the crap out of the plywood.....it was a mutiliation. I'm going to give it a bit of bondo or something but whoa! Maybe it's a blade issue? I just used whatever I found rattling around at the bottom of the case, not sure what it was made for (It looked sharp)
Posted: Sat Jan 28, 2023 1:10 am
A jig saw can be used. A fine-toothed blade will produce better results but will take longer to make the cut, as opposed to a coarse tooth blade. What a bunch of people do is cut about and 1/8" away from the cut line, and then use a powered router to bring the cut to the line by using a guide.
Posted: Sat Jan 28, 2023 3:37 pm
by Fastskiguy
Spent some time making a couple of router jigs for circles. These worked pretty well.
Posted: Sun Jan 29, 2023 5:46 pm
by Fastskiguy
Tom Smit wrote: ↑Sat Jan 28, 2023 1:10 am
Ah now that is a good idea, thanks
Posted: Wed Feb 01, 2023 9:52 am
by Fastskiguy
Making faster progressed than planned and...for the most part...it's going well. But the baffle....oh boy, I'm looking forward to taking another crack at this someday on speaker #2. I have a question about the little lip that is shown in the arrows below...should I take a rasp or file or something and trim back the baffle until it is flush with the horn panels and throat reflectors or is that lip OK? Thanks guys
Joe
Posted: Wed Feb 01, 2023 10:34 am
That lip is far too small to have any effect. Anything less than a quarter wavelength in dimension is invisible to sound waves. A quarter wavelength at 2kHz is 1.9 inches.
