T48 Version one plans
Mongoose
#1 Post by Mongoose »
Are the version 1 plans available anywhere prelab15 update/ does anyone know how different original plans will sound next to the updates we have 6 pre update version 1 cabs but want 8
Re: T48 Version one plans
#2 Post by Grant Bunter »
Hi Mongoose,
Updated plans exist because enough improvements are in them to warrant release of the plans.
Once updated, Bill doesn't keep older versions IIRC.
It won't matter though, building the latest version won't sound any different or have different response.
You'll find 3015LF loaded cabs are much lighter for much the same driver cost...
#3 Post by Bruce Weldy »
Mongoose wrote: Sat Oct 29, 2022 1:43 pm Are the version 1 plans available anywhere prelab15 update/ does anyone know how different original plans will sound next to the updates we have 6 pre update version 1 cabs but want 8
I understand you wanting to keep 'em all the same. I have top-loading T39s. I built more of the old-style after the new plans came out. I just like that look better with no panel on the front.
I guess you can't find the original plans? Or, did you buy those cabs already built?
Mongoose
#4 Post by Mongoose »
Grant Bunter wrote: Sat Oct 29, 2022 2:58 pm Hi Mongoose,
These are 3015lf loaded why I'd like em all to be one designed for that
Bit worried that the improvements made will be audibly better than than the non improved ones making uneven bass response
Mongoose
#5 Post by Mongoose »
Bruce Weldy wrote: Sun Oct 30, 2022 3:48 pm
Brought them off Brian skan they used em for there last unity tribe event in 2004 but they were rushed too so the bracing on the front is missing couldn't say with original version plans that that any internal bracing isn't missing either so any new ones we want to build proper nd retrofit bracing to those without it
