Tuning frequency Simplexx 12 ?
Hi
What is the tuning frequency of the ported Simplexx 12 please ? Can I modify depth of the 4 events in the corner ?
Thanks !
Thanks !
Re: Tuning frequency Simplexx 12 ?
45Hz. Changing it is not advised.
Thanks Bill. It’s the frequency i wanted in my cab. I will order your simplexx 12 plans in few days but I don’t understand what is panel jig. Can you explain to me please ?
The plans for the Panel Jig includes some jigs you can use on the table saw and with a circular saw for making straight cuts and some complex cuts.
The simplexx is a simple build, you shouldn't need any jigs if you have a table saw. If you are using a circular saw and you don't have a jig for it, then I'd get the plan so you can build one....it will make for better, straighter cuts.
Other than ripping I never use my table saw without my panel jig.
Thanks a lot !
With the panels on a Simplexx 12 being so small, I'd just cut 'em all with the fence. My saw's rip fence will cut up to 26 inches, so I only get down the jig for long panels. But, it's danged sure a useful tool to have in the shop.Bill Fitzmaurice wrote: ↑Tue Jul 12, 2022 11:40 am Other than ripping I never use my table saw without my panel jig.
Aside from cut accuracy I use the jig so that I'm pushing the jig, not the work. The stop at the back of the jig also makes kick back nearly impossible.
Good point. I like the panel jig because I can get perfectly square pieces. Some wood isn't exactly square even if it previously cut on a panel saw.Bill Fitzmaurice wrote: ↑Wed Jul 13, 2022 9:39 am The stop at the back of the jig also makes kick back nearly impossible.
Jack 12 (2)
Wedgehorn 6 (4)
Jack 12 (2)
Wedgehorn 6 (4)
Some wood isn't square from the mill.
Years ago I bought 5x5 Baltic birch for some T39s.....they weren't square. None before or none since have been out of square. But, I learned from that to check every piece of plywood before I start cutting it down and assuming a square corner.
And squaring up those bad ones was a real PITA.
Another thing I do is to mark my "squarest" corner and work from that. And I usually mark the square corner on any cutoffs that I'm saving for future use.
