Pyle PDS442 on dr250
For unmatched sensitivity.
joblow88
#1 Post by joblow88 »
Any tought on theses? they are not as loud as the ASD:1001 HF Drivers in the test on ampslab so i would think i might have problem geting the right output but there is also more headroom since they have 250W rms even tho some people say in the comment thay blow at 225. they also lose sesitivaty ad start zigzaging at around 7khz but is it to much that i cannot fix it with a good eq? is there much music produce that go over that? i personaly dont hear any thing pass 15khz.
https://ampslab.com/blog/2018/04/12/pyle-pds442/
https://www.eminence.com/pdf/ASD1001S.pdf
Im i just beeing cheep for the sake of it and i should jus stick with the asd-1001s
Re: Pyle PDS442 on dr250
I wouldn't use anything from Pyle.
ACUA
#3 Post by ACUA »
I agree, I am not impressed with hardly any of the products they slap their logo on
#4 Post by Bill Fitzmaurice »
And that's just it, they don't make anything, they just slap their name on cheap junk.
joblow88
#5 Post by joblow88 »
ok. it is noted thanks a lot
#6 Post by Seth »
If that driver was $5 and I had a speaker already built that I could try it in, I might be inclined to do so... just for the sake of "why not".
But, it's only $10 less than the recommended driver. Even if it was equal in performance and quality, that's not enough of discount to sway me from using a reputable, brand name, professional quality poduct.
Personally, I get a little kick out of bottom of the barrel products that perform close enough to consider passable. However, they're not typically products I'd ever recommend.
In that spirit, I'd say try it if you wanna try it. But, as you're seeing, no one will recommend it. To achieve the advertized results, it's best to stick with the recommended drivers.
I see ASD1001 are out of stock on PE. If that was a motive to considering the Pyle as an option, Amazon shows ASD's as in stock.
joblow88
#7 Post by joblow88 »
Seth wrote: Thu Mar 31, 2022 3:23 pm If that driver was $5 and I had a speaker already built that I could try it in, I might be inclined to do so... just for the sake of "why not".
yeah that was part of the reason but i found some in good ol canada so i wold end up saving on shiping
#8 Post by Tom Smit »
joblow88
#9 Post by joblow88 »
Yup ill go for that it is just taht when i wrote this post they were only 4 listed in stock i wrote to them and they updated it
