Handle Suggestions for XF 212 Cab
AxeMan7
#1 Post by AxeMan7 »
With the angled baffles I am a bit concerned about any decent sized recessed handles for this build. A top handle is an issue for a relatively heavy cabinet, especially if I decide to use 1x poplar.
What have most used, if any, for side handles on the XF 212? Has anyone experienced any rattle/vibration of the flush mounted handles that look like the recessed spring loaded ones?
howiez
Re: Handle Suggestions for XF 212 Cab
#2 Post by howiez »
I've never built an XF, but my son and I used something similar to this on a box about 18x24x36"
https://www.parts-express.com/Steel-Bar-Handle-262-821
no rattles, and lots of screw holes to anchor.
AxeMan7
#3 Post by AxeMan7 »
howiez wrote: Tue Mar 22, 2022 8:44 pm I've never built an XF, but my son and I used something similar to this on a box about 18x24x36"
I think that is too big for my cab. It might intrude into the area where the baffles are glued.
Really looking for flush mount I think.
#4 Post by Bill Fitzmaurice »
There's plenty of room for one of those on each side, just don't try to put them too high.
AxeMan7
#5 Post by AxeMan7 »
Thanks for the suggestions. I ended up buying the recessed Penn-Elcon spring loaded handles and routing the side panels 3/8" deep so as to not enter the inside of the cab.
I f I knew how to post photos I would show the progress.
J_Dunavin
#6 Post by J_Dunavin »
Posting photos is pretty easy actually.
Just resize them on your phone, and when you go to the full editor there is an option to attach files.
