XF210 vs XF212
Guitar cabs both you and your audience can hear better.
AxeMan7
XF210 vs XF212
#1 Post by AxeMan7 »
Is there any reason I can’t use the XF212 plans for 10” speakers and just cut the speaker opening smaller to accommodate the 10” vs 12” speaker?
I don’t have the plans in hand yet, but I can’t see that being a problem unless you say otherwise.
Thanks
Re: XF210 vs XF212
#2 Post by Seth »
Out of curiosity, what benefit would that give you?
Re: XF210 vs XF212
#3 Post by Bruce Weldy »
AxeMan7 wrote: Sun Mar 13, 2022 11:01 am Is there any reason I can’t use the XF212 plans for 10” speakers and just cut the speaker opening smaller to accommodate the 10” vs 12” speaker?
Thanks
I can't think of any problem with that, but it does beg the question.....why? It just makes the cab bigger and heavier.
Re: XF210 vs XF212
#4 Post by Bill Fitzmaurice »
You may, the penalty being a larger cab than is required.
AxeMan7
Re: XF210 vs XF212
#5 Post by AxeMan7 »
Thanks.
Is there a place on the forum or website where I can see the overall dimensions for each before I order the plans?
Re: XF210 vs XF212
#6 Post by Bruce Weldy »
AxeMan7 wrote: Sun Mar 13, 2022 11:40 am Thanks.
The important dimensions for putting a head on top are:
XF210 - 24" wide x 8 1/4" deep
XF212 - 28" wide x 9" deep
AxeMan7
Re: XF210 vs XF212
#7 Post by AxeMan7 »
Thanks.
They make some good smokers out your way. Had one years ago. Wish I kept it.
Re: XF210 vs XF212
#8 Post by Bruce Weldy »
AxeMan7 wrote: Sun Mar 13, 2022 12:46 pm Thanks.
Ha! Hadn't thought about NB Smoker in years. I knew the guy that owned it. He just died last year. Also had a renter that worked there.
You from the area? If so, you are welcome to come check out my XF210.
AxeMan7
Re: XF210 vs XF212
#9 Post by AxeMan7 »
Sorry to hear about that. Was that the owner before W.C. Bradley bought it? I have some friends in San Antonio, and lived in Houston some time back. Haven't been that way in quite a while. Now in Ohio.
Re: XF210 vs XF212
#10 Post by Bruce Weldy »
AxeMan7 wrote: Tue Mar 15, 2022 2:02 pm
It was Ron Snider. He had the playground equipment company too. Went on to own a bunch of real estate here and a venue that I mixed in often. Even mixed the memorial they had there for him.
