Stuffing the back of compression drivers
AcousticScience
When I built my Omnitop 12, I took apart the compression drivers and noticed the chamber behind the diaphragm is uninsulated metal. I put in a small piece of foam. I can't tell whether it sounds any smoother. What do you think? Waste of time or will there be some audible results in some cases?
Re: Stuffing the back of compression drivers
It may make response better, the only way to know is to measure them with and without the foam.
