tuba 60 slimmer?
holzboss
tuba 60 slimmer?
#1 Post by holzboss »
Can i build the TUBA 60 with the LAB 15 (because i already bought the lab 15) but slimmer than the 27 inches or should i stick with the original 27 inches. Because i have smaller doors to one room and it doesnt fit. Or are there some other speaker cases that are slimmer and i can build it with the lab 15??
Re: tuba 60 slimmer?
#2 Post by Seth »
Per the T60 plans, "Going smaller (than 27") would put excess stress on the driver, so if you can’t manage a 27 inch wide cab go with a 1x12."
The T48 can be built as narrow as 18" with a 15" driver.
#3 Post by Bill Fitzmaurice »
If you go slimmer you lose performance. If you must go slimmer use the LAB 12, if one cab isn't enough build two. Never choose a driver and then try to find a cab for it. Choose the cab, then use a driver that has the correct specs for it.
holzboss
#4 Post by holzboss »
so can i build titan 48 with the LAB 15?
tallevan
#5 Post by tallevan »
According to the plans you can build a Titan 48 with a Lab 15 between 18 and 36 inches wide.
#6 Post by Seth »
holzboss wrote: Sun Sep 19, 2021 12:38 pm so can i build titan 48 with the LAB 15?
Yup. :thumbsup:
And it's depth dimension is 24". So even if you build it a full 36" wide, you'll likely still be able to scoot it sideways through narrower doorways.
Go as wide as you can transport.
