Tubas - HT vs prosound
himhimself
#1 Post by himhimself »
Just looking through the plans again as I debate what to build for my HT lowend, and wondering what the real performance difference is between the Tuba24 and the new small TableTuba. They both have the same outer dimensions. I was considering building a couple of the small TT's since they'll fit my space better than the fullsize version, but if a pair of T24's would perform as well, it would give me the flexibility to use them elsewhere for small gigs when the T30s are too much.
Thoughts?
2xT30 (20", 3012LF)
2xT30 (21", 3012LF)
Truck Tuba (MCM)
Re: Tubas - HT vs prosound
The small TT has the advantage for HT because it has a longer horn path. It also doesn't require an expensive driver for best results.
