sub sticky question
himhimself
sub sticky question
#1 Post by himhimself »
So in the sticky, it states "this shows a pair of coupled Tubas using wall loading. With two cabs the distance from the wall is 9 inches for T24s, 12 inches for T30s, 16 inches for T36s. For each additional layer of cabs add another 4 inches distance."
Would the width (which becomes height in this orientation) influence the optimum distance to the wall? How would that work? Is 12" for T30's at max width? mid-point in the range?
When I get my second pair finished, i am hoping to play around with various configurations and measure the outputs to get some real world numbers with my rig. Still have my arm in a sling... :x
2xT30 (20", 3012LF)
2xT30 (21", 3012LF)
Truck Tuba (MCM)
himhimself
Re: sub sticky question
#2 Post by himhimself »
Nobody willing to pontificate?? :noob:
2xT30 (20", 3012LF)
2xT30 (21", 3012LF)
Truck Tuba (MCM)
#3 Post by Grant Bunter »
The statements re distance are pretty definitive.
I'm sure if cab width was an additional modifier it would be mentioned by Bill.
So, you're going to be setting up with the mouths 16" from the walls in the corner.
While it's great you're going to check it all out, I find the opportunity to corner load in all the venues I've worked in, to be less than a handfull.
Don't forget the prime directive either, mouths not between 2' and 8' of a boundary...
himhimself
#4 Post by himhimself »
Grant Bunter wrote: Sat May 08, 2021 4:30 pm I find the opportunity to corner load in all the venues I've worked in, to be less than a handfull.
Agree Grant, I've actually never had it work out to corner load. But wall load, yes. One spot lets me use the exterior wall of a building - 300' long x 40' high smooth concrete boundary!
It's actually the specificity of the distances in the sticky that got me thinking. I would think two slims stacked would work best at the same distance as one fat cab of the same overall mouth width. But cab width isn't mentioned, therefore the question. Maybe Bill will weigh in?
2xT30 (20", 3012LF)
2xT30 (21", 3012LF)
Truck Tuba (MCM)
#5 Post by Seth »
I was thinking along the same lines as Grant, but then considered some other angles.
A T30 with 12's can be built between 16" & 30" wide. A dual loaded cab can be built as narrow as 29"... A dual loaded cab being the equivalent to two single cabs of half the width.
The question arises for me too... Would the dual loaded cab of a slimmer width than a max width single loaded cab necessitate the additional 4 inches and the wider single loaded cab wouldn't? And a 5 foot tall stack of 4 single driver max width cabs would be the same additional 4" as 2 dual loaded slims of less than half the stack height?
Seems a reasonable line of questioning to me. But, I have no idea.
#6 Post by Grant Bunter »
himhimself wrote: Sat May 08, 2021 5:36 pm
Sometimes the answers aren't exactly stated. Perhaps the answer has, in part, just been answered by Bill in your TT question.
Width affects sensitivity in the lows, but not extension or phase response...
Perhaps reinforcing that part of the answer is in the sticky itself, just not at the same spot as where the distances are stated.
in that (paraphrased) "boundary loading provides an extension of the horn mouth" (leading to increased sensitivity, +6dB for a wall, +12dB for a corner, but not extension).
Also remember that doubling cab count adds +6dB, and flattens response in the passband.
It's never easy working this stuff out lol, but I maintain that if width altered the value of the distances stated, it would be mentioned...
#7 Post by Bill Fitzmaurice »
The distance to the wall would be increased with a large enough stack, say eight cabs or more, but at that point you probably wouldn't gain much from aiming at the wall anyway.
