I know this is the wrong way around, but being a dutch cheapskate I also hate to turn down a good opportunity. I got offered a pair of Beyma 10G40 drivers. Apparently these are high power 10" drivers. Are these any good for horn loaded subs and/or Simplex 10 as a bass guitar cab? For the latter I have the impression the mid response might drop just a bit too early, from 3K as opposed to 4k for recommended Eminence drivers. They do seem like they can handle quite a lot of abuse. Table tuba LS for the home and T39 to complement my pair of SLA are also still on the wish list.
10" diameter
8 ohm nominal
Resonant frequency, f s 45 Hz
D.C. Voice coil resistance, R e 6,2 Ω
Mechanical Quality Factor, Q ms 7,1
Electrical Quality Factor, Q es 0,32
Total Quality Factor, Q ts 0,3
Equivalent Air Volume to C ms , V as 49 l
Mechanical Compliance, C ms 241 µm / N
Mechanical Resistance, R ms 2,1 kg / s
Efficiency, η 0 1,40%
Effective Surface Area, S d 0,038 m 2
Maximum Displacement, X max 7 mm
Displacement Volume, V d 266 cm 3
Voice Coil Inductance, L e 0,6 mH
Freq range 45 - 4000Hz
This driver any good?
Re: This driver any good?
They'd be fine in a pro sound sub, or in a two way full range crossed over no higher than 2kHz. Fs is too high for Table Tuba.
Thank you Bill, that is bloody fast. I will consider them for T39 or Simplex 10 then, the latter only if built with tweeter.
