2x12 30" T30 vs 186 horn?
Posted: Thu Dec 24, 2020 11:56 am
Hi, now im getting sick of moving my two 186 horns, its a two mans job atleast... They weigh 170 pounds each and also no handles, but wheels ofc. If i would mount handles on them i would still need help to lift them, if the handles dont break first haha
https://www.speakerplans.com/index.php?id=186horn
I really like the sound of the 186 horns, its very "quick", smooth, effortless, precise, and the kick in the chest outdoors 20+meters away is lovely! Also they can be used up to about 160hz without getting "honky".
Would keep them and add 2 if i was able to stack them alone, weight is the biggest problem
RCF L18P300N loaded, they do handle 120V each all night way before clip or any noticable distortion but isnt very effective below 50hz. (97db 1w1m 2pi at 40hz) (106db at 70hz)
When i mess around with EQ in my Driverack i can get this low thump i love at 30-40hz that i want way more of.
Now i need to HP them with LR48db at 35hz if i need to push them over 100V each to be safe.
Its only a matter of time before i blow a driver i know!
Thats why i want to sell them before disaster, and build new subs that are smaller, not as heavy and goes a bit deeper without the same need of eq..
Subs will be used both indoors and outdoors, playing recorded modern bass heavy dance/rock music mostly. Some RnB and hiphop aswell.
One pair of SLA PRO 4x6 as tops, for now
So, im looking at the spl charts of the Tuba 30, and they seem very promising, alteast with 30" width and dual 12" V-coupled.
Is that chart with 4012 close to 3012lf response?
My math tells me that two 2x12" T30 at 30" V-coupled would match sensitivity of two freestanding 186 horn between 50-70hz where the "kick in the chest" is. But outperform below 50hz, and above 70hz.
But i realise that two T30 dual loaded 30" wide will also be pretty big and heavy, and needs to be HP at 35hz, just like my current subs. Would the T30 still outperform the 186?
Maybe 4 T30 30" single Lab12 would be better then i could hp at 30hz..?
Whats your thoughts?
