Titan 39 to Tuba 30
Ken Lustgarten
Titan 39 to Tuba 30
It’s been a while since I posted here. My needs have changed since I built my system. Four DR200’s have been and still are ideal, but a change of sub is in order. In the past I have provided sound mostly for live events at churches, sometimes inside and sometimes outside. While that will still continue I have had an increasing need of using prerecorded music over the last couple of years.
My current system uses T39’s of which I have 2 left. They are loaded with BP102’s. With some music I find that the bottom is missing. The T39’s go plenty low for live but are a little lacking on prerecorded that has really deep bass. The plan going forward is to build 4 Tuba 30’s with 3012LF drivers at 24” wide. I already have a pair of 3012LF’s laying around because I was going to build another pair of T39’s. I’ll probably sell the remaining pair of T39’s to fund two more 3012LF’s.
I still love the T39’s but needs change over time. They are the best bang for the buck in live sound providing the most punch for size and weight of all the models IMHO. The Tubas will still be fine for live while satisfying the need for deeper bass. I am a strong advocate of not overbuilding. This is why I originally built the T39’s instead of T48’s. More output in the necessary range with a smaller size and less weight! Take some time and be realistic about your needs and then make a wise choice in selecting an appropriate sub.
The older I get the less desire I have to haul heavier or bigger gear then necessary. This concept is causing me to change my system quite a bit. I just built new 6u and 4u racks out of baltic birch to replace a big mixer and a large/heavy rack on wheels. All that’s left to do is apply a finish. The 6u will contain an xti2000 amp (2u), Presonus 24r rack mount mixer (2u), 2 Audiotechnica wireless receivers (1u), and a Furman (1u). The 4u will hold my other 2 xti’s a 1000 and a 2000. The amps have built in DSP with crossovers, eq’s, and a limiter. The result will be a small lightweight system that is modular, only take what is needed. It will also pack better in my van.
Covid has killed just about everything for the time being. When it’s over people will want to get out and have fun. I anticipate a surge in sound needs. Now is the time to prepare!
Re: Titan 39 to Tuba 30
Sounds like a good plan Ken. Welcome back!
Welcome back, Ken.
Sent you a PM....
Sent you a PM....
Ken Lustgarten
Thanks guys!
Another change that is going on due to covid is that I have been getting more into mixing/mastering, not just engineering. I have been working on a small home studio. The room does double duty as my weight lifting room. I think I can come up with a "vocal booth" by hanging lots of close around my rack. I do live in W.V. hence the red neck solution! So far I have setup my PC , usb audio interface, two 27" 4k monitors, Presonus Eris E5xt monitors and Temblor T8 sub. The next project is to make a functional desk and some DIY acoustic treatment. I want to at least treat first reflections and add 2 bass traps in the corners of the back wall. So much work to do, so little time....... Hmmm I wonder what a pair of tubas would sound like in here? In reality subs need to be used very sparingly when mixing. Otherwise the tracks will end up not having enough bass on other systems, flat is what you want for mixing.
Bruce, email sent
Bruce, email sent
So you are a Presonus guy.....me too. I've got three of their mixers and have put some more in other people's rigs. Are you using Studio One?Ken Lustgarten wrote: ↑Mon Dec 21, 2020 8:38 pm Thanks guys!
Bruce, email sent
Ken Lustgarten
Bruce,
Yes, I do love Presonus equipment. I had an old Studiolive 16 channel mixer back when they were still using a firewire interface. It is still in use at the college where I work. For my personal system I use a Presonus 24R rack mount mixer. It only takes up 2u and is controlled by a tablet or computer. This lets me place the equipment on stage and eliminate the use of a snake, again less to lug around. With all of the onboard processing the size of my stack has been reduced to a 1 hand carry for most events. Plus the 24r does double duty for multitrack recording. Their studio monitors are outstanding. Before the next semester starts I would like to get a pair of Scepter S6 monitors and a T10 sub. The T10 has a built in high pass for the monitors with a foot switch that disengages the sub and puts the monitors back to full range. This is a great feature for mixing. My current E5's and T8 will then be used in the office at work.
I have been using Reaper for at least 10 years. It's hard to change after using a product for that long, but I should at least give it a try.
Back to the subs. Another thing that I have been using subs for are movie nights at the college (stopped with covid). This is another place where the T39's are lacking in the bottom end. I have decided on 4 Tuba 30's at 24" wide. The 24" width will pack nicely in my van and be easier to move around, especially through doors/stairs. My T39's will be listed for sale, probably later today! If they don't sell I just might make a 3rd pair of 13" wide Tubas with the BP102's from my T39's. It is handy to have a small light pair. Quite often that's all that is needed and it makes setup a breeze.
I still have 2 of the classic 16.4.2 mixers and an RM32ai. I've mixed on the Series III 24R many times. It's a nice piece of hardware......I even installed one at a venue here in town.Ken Lustgarten wrote: ↑Tue Dec 22, 2020 10:58 am Bruce,
I still like to have faders at my fingertips, but the shows I've been doing lately aren't conducive to using a snake and getting out front - so the Rack mixer is pretty much everything I do now. The RM32 is still firewire, but I have the converter for my laptop although I rarely ever use it.
Ken Lustgarten
The 16.4.2 is the one I started with, it's a great mixer and still in use. I also had a small Presonus firewire interface that had 2 xlr inputs. Now all my gear has usb ports.Bruce Weldy wrote: ↑Tue Dec 22, 2020 12:32 pm
I feel the same way about having actual faders to put my hands on. It gives instant access to anything that may need adjusting quick. The move to computer/tablet control for portable use is only because of the size and weight savings. I am not entirely comfortable with it yet but am getting there. One of the biggest benefits for me is being able to set monitor levels with a tablet in hand rather then screaming back and forth. This also insures that I give them what they need to play together and no more. Excess volume in the monitors is one of the biggest problems that I have and this takes care of it. Monitors pollute the house sound when levels are high, plus cause feedback. Isn't the whole purpose to deliver good sound to the audience?
Ken, what's the width of your T39's?
Ken Lustgarten
The pair are right about 13" wide and have wheels. I made them as narrow as possible for easy transportation to use at small events and weddings. They are made from Arauco 1/2" ply so they are quite light. I'll take a couple of pics tomorrow as I was going to list them in the for sale section.
I see in your sig that you only have 1 3012LF based T39. You need to make/buy a mate for it along with my T39's
Hey Ken, I was wondering if you can provide a detailed update on how your narrow 13" t39 compared to the 24" wide Tuba 30 you were going to build (assuming you executed on it)
I am a small scale DJ using active tops (RCF Art 712a mk5) and play mostly prerecorded music (this a DJ). The t39 (about 22" wide)appealed to me due to the footpring is taller and would fit a bit better in my garage. Am I better off with a titan 39 or tuba30?
QSC 1804 Amp
In Progress: 1x20" Tuba 60 loaded with Eminence Lab12
QSC 1804 Amp
The last time that Ken posted was in 2011.Joman116 wrote: ↑Wed Jun 25, 2025 11:17 pm Hey Ken, I was wondering if you can provide a detailed update on how your narrow 13" t39 compared to the 24" wide Tuba 30 you were going to build (assuming you executed on it)
Trying to be optimisticTom Smit wrote: ↑Thu Jun 26, 2025 9:20 pmThe last time that Ken posted was in 2011.Joman116 wrote: ↑Wed Jun 25, 2025 11:17 pm Hey Ken, I was wondering if you can provide a detailed update on how your narrow 13" t39 compared to the 24" wide Tuba 30 you were going to build (assuming you executed on it)
QSC 1804 Amp
QSC 1804 Amp
What are the odds... last active (signed in) exactly one year ago, to the day.
I'm a little optimistic too, he very well could be keeping up without signing in. Not going to hold my breath, though.
You could try sending him a PM. Depending on his contact preferences, he may get an email notification. And if he's still an authorized builder, his contact info should be in the Authorized Builder list.
himhimself
Doubt you're going to get a reply, Joman116. I debated between titan39s and tuba30s when I was trying to figure out what I wanted to build. No doubt the t39 is the bomb for live music, but I knew I'd be 95% recorded and lots of EDM so that ultimately made my decision to go with the tubas. No regrets. My rig sounds better than any mobile dj setup I've ever heard, and rivals many smaller club installs. Yeah, they're not small. But I've also found that using the v-plate on a 2x2 stack for my mixer makes a decent dj booth and lessens the perception of how big they are. You could probably get fancy and build a frame with a screen around it to really disguise what you have going on. I did something like that once when I was running some little JBL monitors as tops (before I built my OTops), and people were freaking out trying to understand how those little speakers were creating such thundering bass - without realizing they were standing right next to a pile of subs.
2xT30 (20", 3012LF)
2xT30 (21", 3012LF)
Truck Tuba (MCM)
2xT30 (21", 3012LF)
Truck Tuba (MCM)
