Frequency response issue.
Fyrewyre
#1 Post by Fyrewyre »
Hello again everyone. I was just running some tests today on my dual 15 titan cab and as i was playing a frequency sweep from 20-120hz (with all dsp processing off) I realized i have a dramatic dip in the 40-60hz range. It is actually quieter than the 25-35hz range. Is this a room issue with cancellation perhaps? is there anything I can do to remedy the situation?
8- PRV loaded T48 24"
4- Melded Tweeter DR200
4- CD Horn OTOP 12
Re: Frequency response issue.
#2 Post by Seth »
Walk around the room and see if it changes in different locations. Tell us a little about the room (size, shape, etc.) and sub placement.
If it's not the room, check again for leaks.
#3 Post by Bill Fitzmaurice »
A dip centered at 50 Hz indicates either the sub or the mic position is roughly 6 feet from a boundary.
