Looking at building the SLA PRO.
I know how they're supposed to be oriented.
But, they will be hanging from the ceiling and may hang a little lower than I would like.
If mounted horizontally will they sound horrible or not quite as good.
Would that be a big no, no.
Thanks
Question on SLA PRO orientation
Re: Question on SLA PRO orientation
That would be a huge no-no. It puts the output pattern on the wrong axis.
Thanks, that answers my question.
Another question:
What is the dispersion angle of the SLA Pro.
Thanks
Another question:
Thanks
Nominally 120 degrees horizontal 30 degrees vertical, but it varies with frequency, wider in the low frequencies, narrower in the high frequencies, as is the case with most speakers.
