WH6, crossover question
High output and wide dispersion without feedback.
#1 Post by Seth »
Just got all my crossover components in from PE for a pair of WH6's. I went with the electrolytic cap for the low pass and poly cap for the tweeters, as the plans mention.
I'll be putting a DPDT switch in the cabs to switch between the 2 circuits in the 4 pole SpeakOn's and wondered if it might be a good idea to put a 200µf capacitor between the jack and the crossovers to minimize possible damage to the drivers if I accidentally run a subwoofer signal to it.
A 200µf poly cap is unreasonably expensive, but an electrolytic is only about $3.
I just did a little research on the difference between poly and electrolytic caps for crossover use and it looks like electrolytics are avoided for high frequency use for some reason that I don't quite understand yet. But, there was some mention of it possibly being okay to use the two in series.
Would adding a 200µf electrolytic capacitor in series between the jack and the crossovers create problems with the sound quality? Should/could I just put it inline on the positive lead before the woofer lowpass filter and wire the tweeter filter direct (not through the 200µf cap)?
Will this even do what I'm intending it to do? Is 200µf an appropriate value to use for the purpose? Is it even a good idea?
Thank you :thumbsup:
Re: WH6, crossover question
Don't run a subwoofer signal into it. You can never do that if you wire the subs to 1+ 1- and mains or wedges to 2+2-. Problem solved.
Polys are used for high frequency signal pass through because they have low ESR, equivalent series resistance. High ESR doesn't matter much on low pass shunts to ground, so electrolytics are OK there.
#3 Post by Seth »
Bill Fitzmaurice wrote: Thu Nov 05, 2020 10:37 pm Don't run a subwoofer signal into it. You can never do that if you wire the subs to 1+ 1- and mains or wedges to 2+2-. Problem solved.
Thank you Bill. That certainly sounds like it would be the best practice.
All my mains and subs are wired as you suggest. However, I'm making my monitors with a switch, so I can get 2 mixes per cable run to limit the number of runs/wires. I'm trying to avoid damage if the wedge accidentally gets plugged into a main/sub lead, which is unlikely... but would still like to add the safeguard if it's a viable solution.
Is adding the capacitor in series (not a shunt to ground) before the inductor on the low pass filter a bad idea, due to ESR? Or, would it be okay (and work as I intend)?
#4 Post by Grant Bunter »
A capacitor in series to the filters after the input jack/speakon becomes the simplest form of a high pass, and maybe that's what you're after.
I don't understand why you need a switch.
Mark the monitors that run off 1+ and -, or 2+ and -, as such on the speakon panel plate of each monitor, or, if not using a plate, just mark the mons near the input 1 or 2. Wire them appropriately.
When setting up, place them appropriately.
When you set up, you can still use any 4 core cable with NL4's wherever you like, but only those monitors plugged into 1+ and - will work on that amp output, and 2+ and 2- on the other (based on a break out panel from your amp rack!).
While that is a little contrary to Bill's suggestion above, ordinarily I set up everything I own by myself, so it doesn't matter, as long as I know what I've done (and I do). However, sometimes you get help, wanted or other wise, and, to me, it makes it much simpler to be able to say "yep, if that lead's long enough, plug it in there and there, daisy chain them like this", and it's all good (I always check anyway).
I always set up FOH first, and monitors last (actually lighting is last, but that's not audio lol).
That helps decrease screw ups as well...
#5 Post by Bill Fitzmaurice »
SethRocksYou wrote: Thu Nov 05, 2020 10:54 pm I'm trying to avoid damage if the wedge accidentally gets plugged into a main/sub lead
Color code the connectors.
#6 Post by Bruce Weldy »
Is this really a problem? If you use a labeled rack panel for all connections, it would be pretty hard to accidentally hook it up wrong. Now, if you are fishing around in the back of a rack to plug directly into and amp - then that leads to the possibility of making a mistake.
All of my cables are the same and every box uses 1+/1-. Plus, I tend to have the master volume on every monitor send pulled back and bring them up slowly for sound check. That way even is something is wired wrong - you'll know before you fry something.
You can't protect against every little incident of dumbassery (coined by my friend Earl - RIP), but if you use a rack panel, labels, and are careful - you should never blow anything up.
#7 Post by Seth »
Bill Fitzmaurice wrote: Fri Nov 06, 2020 8:59 am
I'd still like to add a safeguard if it's a viable solution.
#8 Post by Seth »
Grant Bunter wrote: Fri Nov 06, 2020 4:13 am A capacitor in series to the filters after the input jack/speakon becomes the simplest form of a high pass, and maybe that's what you're after.
Thanks for addressing my question Grant and also sharing some smart options and safe setup practices. I suppose I don't NEED a switch. A switch does occur to me as a more versatile option though, not having to keep track of which wedge is wired which way.
#9 Post by Bill Fitzmaurice »
The level of protection it adds is minimal, it's only a first order filter, and it will cause a loss of midrange response.
#10 Post by Seth »
Bruce Weldy wrote: Fri Nov 06, 2020 10:08 am Is this really a problem? If you use a labeled rack panel for all connections, it would be pretty hard to accidentally hook it up wrong. Now, if you are fishing around in the back of a rack to plug directly into and amp - then that leads to the possibility of making a mistake.
It's not a problem and I don't foresee it being a problem, but it's still a possible mistake. If not on the hard wired end, on the DSP end. I've made similar mistakes before, adjusting one thing in the DSP, that I thought was another (similar to making adjustments to an Aux Bus when I intend to be on the Main Bus). I don't intend or expect to make that sort of mistake. I don't intend or expect to ever hook it up to the wrong amplifier channel. However, shit happens, and the way I intend to have these wired leaves that door open. The best solution would be to wire it as Bill suggested, but short of that, all we/I can do is preventative measures. If I can put a reasonable safeguard against my own dumbassary (I'm certainly not immune) at a reasonable cost, it would seem silly not to. A $3 preventative measure vs. a probably never but still possible to blow $50 driver, I'll take the $3 insurance please.
But, the questions still remain... Is it an option? Will it have a detrimental effect on sound quality? Will it work for what I want it to do? Any reason not to add it in there?
#11 Post by Seth »
Bill Fitzmaurice wrote: Fri Nov 06, 2020 11:46 am The level of protection it adds is minimal, it's only a first order filter, and it will cause a loss of midrange response.
Good info. Thank you Bill. That's the sort of information I was looking for. :thumbsup:
#12 Post by Bruce Weldy »
SethRocksYou wrote: Fri Nov 06, 2020 12:04 pm
I hear ya' about being safe if it's a cheap option and works. I just don't think it's that big of a risk if you keep all your ducks in a row...... If you always soundcheck the system by bringing up the faders from zero - you'll catch those weird problems should they occur......before they can cause a problem.
