THTLP Dual Lab 12
mj90210
THTLP Dual Lab 12
#1 Post by mj90210 »
I am assuming a dual Lab 12 would be an option in a THTLP. What would be the minimum width?
2xDR300's
4xDual-30” Tuba 60’s
Simplex 21" Eminence NSW6021
1x20” THT
TLAH‘S
SLA Center-9 driver and Surrounds
SLA pros
TrT 10" Driver-10" Wide
Auto Tuba 10" Driver
Re: THTLP Dual Lab 12
#2 Post by Bruce Weldy »
Only a 15 or single 12 is listed in the plans....no dual 12. I suppose you could do it, but you'd probably want to go out to 30 inches......best see if Bill chimes in on this.
#3 Post by Bill Fitzmaurice »
You can't smooth room modes with two twelves when they're both in the same enclosure.
mj90210
#4 Post by mj90210 »
I should of clarified my goal earlier.
I have space for two 24” and larger thtlp’s and have quite a few lab 12’s not being used. Instead of buying two 15” Daytons, I figured I could easily load the LP version with the lab 12’s that aren’t being used.
Thanks
2xDR300's
1x20” THT
TLAH‘S
SLA pros
#5 Post by Bill Fitzmaurice »
A 2x12 would have to be twice the panel width of a 1x12.
