Crown XLS 1500
Posted: Sat Aug 01, 2020 8:53 pm
by djtrumptight
Is anyone familiar with how a Crown XLS 1500 will perform with 3) DR 250'S per side ? I dont plan on running that way too often but i will have 6 DR 250'S as soon as i finish my build,i dont really wanna buy another amp for rare occasions plus i cant find another XLS 1500 for sale or i would buy it,i like to keep things uniform,my reason for building the older plan DR 250'S.
Also,if i use 6 DR'S and 2 stacks of 4 v plated T-48's,wouldnt the volume of the T-48's plus the 3db from the V plates give me the volume of 12 T-48's ?
Re: Crown XLS 1500
Posted: Sun Aug 02, 2020 5:54 am
by Grant Bunter
3 a side is just ok to maximum voltage (40V) for the DR’s with an xls 1500, but there is no headroom.
You need to double cab count to add +6dB ( eg 8 x T48’s doubled to 16 x T48’s) and that’s not the same as 2 stacks of 4 x T48’s V plated. While the V plating helps, there’s no free lunch...
Re: Crown XLS 1500
Posted: Sun Aug 02, 2020 10:11 am
I use 3-1500s for my subs running bridged....not applicable to your situation, but they have been steady for years of service.
They should be fine running 3 DRs per side. Calculates to 45-48 volts output.....I can't imagine every running DRs up to 40 volts....
I use a 2500 for my 4 OTops, because it just worked out that way in my amp configuration as my rig grew.
You can get the old-style 1500s pretty cheap.....I'd use 'em in a heartbeat in your situation.
Re: Crown XLS 1500
Posted: Sun Aug 02, 2020 8:30 pm
by jimbo7
I got a 1500 and pushed it briefly to 40v with a T39 on each channel. Didn't skip a beat.
Re: Crown XLS 1500
Posted: Tue Aug 04, 2020 7:45 pm
by Seth
Would an
XLS 1502 suite you? There's one "used - like new" for $340 and a 2502 used for $445 (darn good deal)
Re: Crown XLS 1500
Posted: Wed Aug 19, 2020 1:47 pm
by djtrumptight
Seth that would work but i like to keep things as uniform as possible.
Re: Crown XLS 1500
Posted: Thu Oct 01, 2020 10:43 pm
by nola50
What do you think about an XLS1500 with 2 Jack 12L's for PA?
I also have an XLS2500, but I use that with a Tall Boy 15 on one channel.
Thanxabunch!
Re: Crown XLS 1500
Posted: Fri Oct 02, 2020 8:08 am
nola50 wrote: ↑Thu Oct 01, 2020 10:43 pm
Thanxabunch!
That will work just fine.
