Crown XLS 1500
djtrumptight
Crown XLS 1500
#1 Post by djtrumptight »
Is anyone familiar with how a Crown XLS 1500 will perform with 3) DR 250'S per side ? I dont plan on running that way too often but i will have 6 DR 250'S as soon as i finish my build,i dont really wanna buy another amp for rare occasions plus i cant find another XLS 1500 for sale or i would buy it,i like to keep things uniform,my reason for building the older plan DR 250'S.
Also,if i use 6 DR'S and 2 stacks of 4 v plated T-48's,wouldnt the volume of the T-48's plus the 3db from the V plates give me the volume of 12 T-48's ?
2 Autotuba's MCM 55 2421
8 T48's 24"wide 3015 LF
2 SLA HT systems
1 Table Tuba Dayton DCS 255-4
2 T 39's 20" wide 3012 LF
1 T-18 13" wide MCM 55 2421
2 SLA Pro's
Re: Crown XLS 1500
#2 Post by Grant Bunter »
3 a side is just ok to maximum voltage (40V) for the DR’s with an xls 1500, but there is no headroom.
You need to double cab count to add +6dB ( eg 8 x T48’s doubled to 16 x T48’s) and that’s not the same as 2 stacks of 4 x T48’s V plated. While the V plating helps, there’s no free lunch...
Re: Crown XLS 1500
#3 Post by Bruce Weldy »
I use 3-1500s for my subs running bridged....not applicable to your situation, but they have been steady for years of service.
They should be fine running 3 DRs per side. Calculates to 45-48 volts output.....I can't imagine every running DRs up to 40 volts....
I use a 2500 for my 4 OTops, because it just worked out that way in my amp configuration as my rig grew.
You can get the old-style 1500s pretty cheap.....I'd use 'em in a heartbeat in your situation.
jimbo7
Re: Crown XLS 1500
#4 Post by jimbo7 »
I got a 1500 and pushed it briefly to 40v with a T39 on each channel. Didn't skip a beat.
Re: Crown XLS 1500
#5 Post by Seth »
Would an XLS 1502 suite you? There's one "used - like new" for $340 and a 2502 used for $445 (darn good deal)
djtrumptight
Re: Crown XLS 1500
#6 Post by djtrumptight »
Seth that would work but i like to keep things as uniform as possible.
2 SLA HT systems
2 SLA Pro's
nola50
Re: Crown XLS 1500
#7 Post by nola50 »
What do you think about an XLS1500 with 2 Jack 12L's for PA?
I also have an XLS2500, but I use that with a Tall Boy 15 on one channel.
Thanxabunch!
Re: Crown XLS 1500
#8 Post by Bruce Weldy »
nola50 wrote: Thu Oct 01, 2020 10:43 pm What do you think about an XLS1500 with 2 Jack 12L's for PA?
Thanxabunch!
That will work just fine.
