Titan 39 12" driver choices
Posted: Wed Jul 08, 2020 9:34 pm
I’m planning on building a pair of T39’s soon and I’ve found some alternatives to the recommended 12” drivers that I haven't seen discussed here. I don’t know much about audio brand quality so I was hoping to get some people’s opinions on them. Has anyone ever used these brands or even these specific drivers in a BFM designed sub before? How do they sound or how do you think they would sound?
Dayton PA310-8
https://www.daytonaudio.com/images/reso ... -sheet.pdf
Fs = 39 hz
Qts = 0.29
Xmax = 5mm
Vas = 91.8 L
Vd = 265.5cc
LaVoce SSF 122.50L (possibly sold @ loudspeakersplus and parts-express)
http://www.lavocespeakers.com/lavoce/as ... ER_A.a.pdf
Response curve attached as image
Fs = 41 hz
Qts = 0.43
Xmax = 11.5mm
Vas = 59.2 L (slightly low)
Vd = 609.5cc
Fane Sovereign 12-500LF (sold @ Thomann)
https://www.fane-international.com/down ... 141117.pdf
Fs = 50 hz
Qts = 0.51 (slightly high)
Xmax = 5.5mm
Vas = 66 L
Vd = 298cc
Fane Sovereign Pro 12-500 (sold @ Thomann)
Fs = 43 hz
Qts = 0.314
Xmax = 6mm
Vas = 107 L
Vd = 339cc
Dayton's and Fane’s SPL charts seem to indicate higher output than a Delta12-LFA from 40-100 hz. The LaVoce is higher from 40-75 hz. Someone please correct me if I’m wrong.
Dayton PA310-8
Fs = 39 hz
Qts = 0.29
Xmax = 5mm
Vas = 91.8 L
Vd = 265.5cc
Fs = 41 hz
Qts = 0.43
Xmax = 11.5mm
Vd = 609.5cc
Fs = 50 hz
Xmax = 5.5mm
Vas = 66 L
Vd = 298cc
Fs = 43 hz
Qts = 0.314
Xmax = 6mm
Vas = 107 L
Vd = 339cc
