Simplex 21" Drivers
mj90210
Simplex 21" Drivers
#1 Post by mj90210 »
Hello,
Recently there have been 21" drivers released that are little less expensive the the Eminence NSW-6021. One is made by Dayton and the other by Lavoce. I understand the simplex 21 was designed for the Eminence but I figured I would ask. Would it be worth it or even possible to keep the box volume the same but change the length of ports to accommodate either driver? I "played" around in WinISD using the Simplex 21 enclosure specifications but results didn't warrant the the savings of $300, at least for myself.
However the Dayton seems like a decent driver for the money, maybe it is worth a modification even as a home theater model.
Let me know your thoughts.
https://www.parts-express.com/dayton-au ... m--295-050
2xDR300's
4xDual-30” Tuba 60’s
Simplex 21" Eminence NSW6021
1x20” THT
TLAH‘S
SLA Center-9 driver and Surrounds
SLA pros
TrT 10" Driver-10" Wide
Auto Tuba 10" Driver
jimbo7
Re: Simplex 21" Drivers
#2 Post by jimbo7 »
I've never looked at those plans. Wow what a monster driver the Eminence is!
I don't understand why you wanna redesign it. The Dayton driver will work based on the recommended specs.
#3 Post by Bruce Weldy »
jimbo7 wrote: Mon Jun 29, 2020 6:45 pm I've never looked at those plans. Wow what a monster driver the Eminence is!
+1
Specs are indeed really close.....other than xmax.....21mm for the Eminence and 11mm for the Dayton. Have to keep the voltage within reason....of course, wanting a 21 in. driver means that reason is pretty much left the barn, right? :mrgreen:
Strange Kevin
#4 Post by Strange Kevin »
The Fs and and Qts are close enough, but the Vas is about double on the Dayton (442 Liter) compared to the Eminence (225L).
At less than half the price it might be worth the trouble... but with the shorter Xmax, I doubt it would beat the recommended driver the the S18 - Home Theatre.
jimbo7
#5 Post by jimbo7 »
Strange Kevin wrote: Mon Jun 29, 2020 10:29 pm The Fs and and Qts are close enough, but the Vas is about double on the Dayton (442 Liter) compared to the Eminence (225L).
You gotta pay to play.
From what I understand of VAS is that the Eminence is a more efficient speaker and needs less power to move the cone to produce the same results. Please correct me if I'm wrong.
#6 Post by Bill Fitzmaurice »
Vas only major effect is on the size of the box.
jimbo7
#7 Post by jimbo7 »
Bill Fitzmaurice wrote: Tue Jun 30, 2020 8:04 am Vas only major effect is on the size of the box.
I did notice that the Dayton vented volume is almost 3x greater
