Hi All,
I'm having a bit of difficulty with cabinet paint.
I just finished a couple of cabinets with black Duratex, using the special little textured roller.
They turned out beautifully. The paint dried quickly, it looks like the bumpy business.
10 days later, I see that my rubber amplifier feet are forming a sticky bond with the 10-day old duratex.
When I prise my amp head loose, the Duratex has been flattened in little circles under the feet.
I previously used a cabinet paint available here in the UK called Tuffcoat. That's even worse! The paint and some of the plywood bonds to the amp feet, and comes up with it. It's like PL Premium!
What's the deal? Does everybody just live with this?
Enough to drive a man to Tolex..
Duratex hardness
Re: Duratex hardness
You need to cure the cab for a day or two in the hot sun to get it fully hardened.
+1Bill Fitzmaurice wrote: ↑Thu May 21, 2020 9:24 am You need to cure the cab for a day or two in the hot sun to get it fully hardened.
I don't always set them in the sun, but high humidity definitely increases the curing time. Even if you just don't set anything on 'em for several days, that will probably be enough.
I imagine that London is probably humid all the time.
- Jason Stromberg
If you are planning to ship cabinets that have been coated with Duratex i recommend 10 days minimum cure time, it dries quick but the cure time takes a bit.
From the document "Applying DuraTex"
Make sure your work area will maintain a temperature of at least 65°F so the DuraTex will cure properly once it’s
dry. The curing process takes a few days, so it’s best to keep the coated cabinet in a warm area.
CURING: DuraTex will air dry and the drying time will depend on the amount of relative humidity in the area. On real dry
days with low relative humidity, the product will dry within an hour. On hot muggy, rainy days with high relative humidity, it
may take 2 or 3 hours to dry fully. Once the DuraTex is dry, it begins to cure and it may feel a little soft the next day. Don’t
worry. DuraTex will cure to a hard finish within a few days and it gets its maximum toughness after about 7 days. You can
speed up this curing process by the addition of heat such as in a drying oven by raising the temperature to 140 degrees and
drying the cabinet for about 30 minutes. That makes handling, stacking and packaging easier for rapid shipping. Some
customers load their cabs into the back of a van parked in the sun. Cheap oven!
Thanks all.
It has been ten bloody days, but it's going to be beautiful weather for the next few days. I'll put them out and see what transpires.
Regards
Regards
I've had it come off on my cables that the cab was laying on in my trunk. I'm sure it's a combination of heat/cold and maybe chemical reaction. The best part is you can touch it up and never know the difference.
