table tuba driver size
himhimself
#1 Post by himhimself »
Looking at the Dayton drivers for the TT, the 10" is almost 50% more than the 8". How much of a performance gain does one get with the larger driver? I'm thinking to build two for my home theatre, and from what I've read, seems even 10W is enough to shake the house with the 8s. So that's how I'm leaning, but wanted some confirmation (or otherwise) that I'm not making a mistake. BTW, system gets used for both music and movies, but really never at brain melting volumes. These will replace an old 15" DBX sub.
thanks!!
2xT30 (20", 3012LF)
2xT30 (21", 3012LF)
Truck Tuba (MCM)
Re: table tuba driver size
There is no performance gain other than potentially higher output due to more Vd. I first tested mine with a ten, then put in an eight, and never bothered to put the ten back in.
himhimself
#3 Post by himhimself »
thanks Bill. Love it when decisions are easy to make!
2xT30 (20", 3012LF)
2xT30 (21", 3012LF)
Truck Tuba (MCM)
ketoet
#4 Post by ketoet »
i have 2 ttls with the 8" tang band driver. max output is way more than i need
1 x THT
1 x autotuba
2 x dr250 melded
2 x wedgehorn 10
2 x tlah
#5 Post by Seth »
ketoet wrote: Tue Aug 18, 2020 2:06 pm i have 2 ttls with the 8" tang band driver. max output is way more than i need
Too much is the perfect amount... if you ask me 👍
