I just want to verify that the high pass crossover is the same for the 2, 4, and 6 tweeter options in the SLA Pro. Is that correct? Same circuit for all?
Thank you
SLA Pro High pass crossover
Re: SLA Pro High pass crossover
Yep....I only see one option in my plans....SethRocksYou wrote: ↑Mon Mar 23, 2020 10:48 am I just want to verify that the high pass crossover is the same for the 2, 4, and 6 tweeter options in the SLA Pro. Is that correct? Same circuit for all?
Thank you
Everyone seems to be out of the Dayton 4 ohm resistors. Is a 3.9 or 4.3ohm an option or should I just hunt down a 4ohm resistor?
Within 10% is fine. I would think a 3.9 was better than a 4.3 though, closer anyway.SethRocksYou wrote: ↑Mon Mar 23, 2020 11:41 am Everyone seems to be out of the Dayton 4 ohm resistors. Is a 3.9 or 4.3ohm an option or should I just hunt down a 4ohm resistor?
Doesn't matter because....Grant Bunter wrote: ↑Mon Mar 23, 2020 3:15 pmWithin 10% is fine. I would think a 3.9 was better than a 4.3 though, closer anyway.SethRocksYou wrote: ↑Mon Mar 23, 2020 11:41 am Everyone seems to be out of the Dayton 4 ohm resistors. Is a 3.9 or 4.3ohm an option or should I just hunt down a 4ohm resistor?
Geez....sorry.....I'm so damned bored.. even started my daughter's taxes....and now they ain't due til July....
4.3 is better, as the purpose of that resistor is to set the minimum impedance load the amp can see at very high frequencies, where the capacitive nature of piezos causes their impedance to be very low, approaching a dead short.Grant Bunter wrote: ↑Mon Mar 23, 2020 3:15 pm Within 10% is fine. I would think a 3.9 was better than a 4.3 though, closer anyway.
Ordered. Thanks everyone.
