Construction methods
Vic
#1 Post by Vic »
Bill
I had an idea for the construction of the cabs I plan to build
Instead of rebating (dadoing in USA) could I use 12mm quadrant or fillet timber (right angle triangle cross section) to re-enforce the side to horn component joints. Would this affect the volume significantly, or cause problems with the air movement?
Thanks
Vic
DefZone Promotions - www.myspace.com/defzone
Live Sound - www.vwpsounds.com
What cabinet?
Vic
#3 Post by Vic »
Soz
I am planning to build some Wedgehorn10's, some DR290, possibly some DR300 and some T48's
Thanks
Vic
#4 Post by Bill Fitzmaurice »
??? none of those use dados.
Vic
#5 Post by Vic »
Not in your designs
But some are routering out the side panels to accept the horn components. Would using extra bracing be detrimental to the tuning of the cabs?
#6 Post by Bill Fitzmaurice »
I couldn't say without seeing a diagram of the cab in question and your intended alterations.
