Bass cabinet choices?
T_Gowan
#1 Post by T_Gowan »
So much experience here , I have to ask. I sometimes just go IEM if we have good sub support, when not I use a SWR Workingmans 2X10 mainly for the bottom on stage. I have an Avitar 4x10 with Eminence Neos that I only drag out once a year. Was thinking of taking the Neos and making 2 singles or 2 2x10 to make then I would have the 2x10 or the 4 x10 equivalent should I need it.
SOOOOO what cab would you suggest for this .
(was thinking of putting the Neos in the SWR to make it lighter)
Thanks for all your inputs.(hoping for lots) :hyper: :hyper:
IN PROGRESS Jack 10 Lite x2, hopefully 4
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
Re: Bass cabinet choices?
#2 Post by Grant Bunter »
In order to see if you can use the neo's, and in what cab, you need the TS parameters for them.
You'd have to get them via Eminence after recording all the numbers you can find on one driver...
