Amp for SLA Pro
rfauske
Amp for SLA Pro
#1 Post by rfauske »
Hi,
Whats an appropriate size for an amp for it. Already got one that is 2*200W in 8 ohm som just wondered if that would be ok to use ?
Re: Amp for SLA Pro
#2 Post by Bruce Weldy »
rfauske wrote: Sat Jun 22, 2019 11:45 am Hi,
That should be fine...you didn't say what model it is....so, be aware that some manufacturers really inflate their output numbers.
But, they should be pretty danged loud at half that.
rfauske
Re: Amp for SLA Pro
#3 Post by rfauske »
The amp is an newclassd, its rated for approx 220w at 8ohm and the double at 4ohm.
Built with a 850va torodial, so the 2x200w should be real watts.
But thanks, then I will try to use that for the tops and just get a new one for the subs for now.
