SLA Pro Airtightness
Short and Transmission Line Arrays for Pros
lowbob
#1 Post by lowbob »
I'm building a pair of 2X6 SLA pro's and am in the wiring stage. The instructions say "Slide the first Speakon into it's hole, seal it airtight with hot melt glue." In my ignorance, I purchased Neutrik NL4MP-ST, which are not airtight. I probably should have gotten NL4MPR instead. Any thought whether I should get the NL4MPR's or live with the NL4MP-ST's? Since it is a ported design, I thought the leaky connectors would be less of an issue.
Thanks,
Rob
No matter how many times I cut it, it's still too short.
Optimist - The glass is half full.
Pessimist - The glass is half empty.
Engineer - The glass is twice as big as it needs to be.
Re: SLA Pro Airtightness
The only thing you might notice is some slight whistling of air through the connector. It won't affect anything else. Contrary to intuition a ported cab doesn't have less internal air pressure than sealed, it has more.
lowbob
#3 Post by lowbob »
Thanks. I'm pressing on.
Rob
ACUA
#4 Post by ACUA »
Bill Fitzmaurice wrote: Sun Jun 09, 2019 4:00 pm The only thing you might notice is some slight whistling of air through the connector. It won't affect anything else. Contrary to intuition a ported cab doesn't have less internal air pressure than sealed, it has more.
I admit my intuition does that hard core!!!
