Crossover Question
TXATC
Crossover Question
#1 Post by TXATC »
Hello all,
It’s been awhile since I posted last. Had a question about the SLA crossovers. If I were to go with an alternate drive that meets the specs, would the published crossover be adequate, or would I need to find a way to tweak it specifically for the alternates? I’m not so good with the numbers. I found all the parts to create my own according to the plans, just wondering if I would be out of luck if I pulled the trigger.
Thanks in advance!
Semper Fi
TX
Re: Crossover Question
If the driver specs are OK the crossover is OK.
TXATC
#3 Post by TXATC »
Thanks for the quick reply Bill!
Semper Fi
TX
TXATC
#4 Post by TXATC »
Follow up question. Does the voltage of the caps matter? I was looking to source them from Madisound and all the ones I am looking at are the MDL XPP 250V ones. I know that too low won’t work, but will the 250V ones be ok? The plans just specify the microfarads needed. I tried to go to a local component shop but all they had there were mylar ones.
Semper Fi
TX
#5 Post by Bruce Weldy »
TXATC wrote: Mon Mar 11, 2019 5:18 pm Follow up question. Does the voltage of the caps matter? I was looking to source them from Madisound and all the ones I am looking at are the MDL XPP 250V ones. I know that too low won’t work, but will the 250V ones be ok? The plans just specify the microfarads needed. I tried to go to a local component shop but all they had there were mylar ones.
My plans say over 150 volts.....first couple of lines in the crossover section. Check your plans again. They may be newer than mine.
TXATC
#6 Post by TXATC »
Thanks for the info Bruce. I rechecked the section and didn’t see anything about the voltage, but if yours say 150+ then i’ll run with em. Thanks again!
Semper Fi
TX
#7 Post by Bruce Weldy »
TXATC wrote: Mon Mar 11, 2019 5:27 pm Thanks for the info Bruce. I rechecked the section and didn’t see anything about the voltage, but if yours say 150+ then i’ll run with em. Thanks again!
I was checking the SLA Pros.....not sure which you have.....
#8 Post by Bruce Weldy »
Bruce Weldy wrote: Mon Mar 11, 2019 7:00 pm
Just looked and my SLA plans don't mention the voltage....
TXATC
#9 Post by TXATC »
Just the SLA's. I suppose they willl have to do now, since i already ordered em lol!
Semper Fi
TX
#10 Post by Bruce Weldy »
TXATC wrote: Mon Mar 11, 2019 7:14 pm Just the SLA's. I suppose they willl have to do now, since i already ordered em lol!
I'm sure they'll be fine....
But, that's why I always order the crossover parts from Leland.....you know you're getting the correct ones.
With the hi-fi SLA no one makes poly or mylar crossover caps that have too low a rating.
TXATC
#12 Post by TXATC »
Thanks guys! I hope to have a build post up soon! I’ve put this off for FAR too long.
Semper Fi
TX
