cut and glued tweeter arrays
DJ Big Ronn
#1 Post by DJ Big Ronn »
I thought that this may help out a few people. After cracking several tweeters trying to drill new mounting holes, I came up with the idea of just melting new holes with the soldering iron. It punches thru effortlessly and then you can heat up the end of a metal rod to make the countersink so that the screws will sit flush. It works great!
