I need a new bass git cab
T_Gowan
#1 Post by T_Gowan »
Not sure which page to put this under so I put it here.
I currently have a SWR 210 cab with an Ampeg PF500 head. The little SWR is ok but I would like something lighter. This is mainly used for rehearsal and on stage personal monitor. Suggestions ? I play 5 string.
Thanks
TomG
IN PROGRESS Jack 10 Lite x2, hopefully 4
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
Re: I need a new bass git cab
#2 Post by Tom Smit »
W10 should be about 20 lbs. lighter.
T_Gowan
#3 Post by T_Gowan »
Hadn't even thought of W10. Was thinking Jack or Omni. Will this do what my old SWR did as far as bottom etc.
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
#4 Post by Bruce Weldy »
T_Gowan wrote: Tue Oct 09, 2018 8:32 am Hadn't even thought of W10. Was thinking Jack or Omni. Will this do what my old SWR did as far as bottom etc.
In my opinion - no. An Omni or Jack would be my suggestion. A single Jack to start with some kick-back legs or an amp stand to lean it back like a monitor.
#5 Post by CoronaOperator »
T_Gowan
#6 Post by T_Gowan »
So a Jack 10. is the Deltalite II 2510 the premium driver, 8 ohm?
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
#7 Post by Bruce Weldy »
T_Gowan wrote: Tue Oct 09, 2018 10:46 am So a Jack 10. is the Deltalite II 2510 the premium driver, 8 ohm?
You are playing a Low B Bass......I'd go with the Jack 12 using a 3012HO.
2510 xmax - 4.2
2512 xmax - 4.9
3012 xmax - 6.2
The extra excursion is well worth it if you are going low and hitting it very hard.
#8 Post by Bill Fitzmaurice »
Bruce Weldy wrote: Tue Oct 09, 2018 1:30 pm You are playing a Low B Bass......I'd go with the Jack 12 using a 3012HO.
Maximum SPL of the J12 is higher. In the intended usage for the W10, as a personal monitor, the additional output of the J12 compared to W10 wouldn't matter, so take that into consideration.
T_Gowan
#9 Post by T_Gowan »
What are approx. dimensions and weight for the 12.
DR200 x2
T24 16" x2
T39 20" x2
DCX2496
DEQ2496 x2
FBQ2496
Mackie DL1608
J_Dunavin
#10 Post by J_Dunavin »
You read this?
viewtopic.php?f=13&t=25053
Is go with the jack
