PL vs. wood glue
himhimself
PL vs. wood glue
I've become a huge fan of PL, using it for lots of other types of projects around the house too. However, I have a question. Is there any downside to using a good wood glue for some of the face to face joints? For instance, the woofer spacer to baffle (assuming no mesh), or some of the places specifying to double up 1/4" ply to give 1/2" thickness. PLs great, but the mess is sometimes annoying.
2xT30 (20", 3012LF)
2xT30 (21", 3012LF)
Truck Tuba (MCM)
2xT30 (21", 3012LF)
Truck Tuba (MCM)
Re: PL vs. wood glue
If the woofer is sitting on top of the spacer, then yes it has to be airtight and you should use PL. If you just mean the blocks behind the baffle in some designs for holding the driver screws, then no.himhimself wrote: ↑Mon Aug 20, 2018 2:16 pm I've become a huge fan of PL, using it for lots of other types of projects around the house too. However, I have a question. Is there any downside to using a good wood glue for some of the face to face joints? For instance, the woofer spacer to baffle (assuming no mesh), or some of the places specifying to double up 1/4" ply to give 1/2" thickness. PLs great, but the mess is sometimes annoying.
PL is like making love. You get better at it over time.
And get some surgical gloves.....it's worth the small expense....
And don't wipe it, you will make a bigger mess. Let it set up for ~4 hours (temp, humidity depending) until it is not tacky any more but still very pliable and then tool it.
I use these cheap artist tools from Michaels:
Let it set for 4-5 hours, too long and it will get too hard, too soon and it is still messy:
Then it will tool very easy, finished result:
After a bit of practice you can get the joints looking perfect even with 1/8" gaps in the wood. I don't even remotely try to make my cuts perfect anymore, not worth the effort.
- James Champer
It is easier after just a couple of hours but.. If you have sharp chisels, and I mean sharp, it doesn't matter when you decide to trim the squeeze out. I've even waited several days.
And let's be real here, every wood chisel should be sharp
I usually wait an hour or two, then run a utility knife down one panel then the other. Leaves a nice corner and the piece of PL just falls away.
- Rune Bivrin
For that particular application I have no doubts about using regular wood glue. Just cover the surfaces completely. Not getting that air tight is almost a feat. I used regular wood glue for the doubling up of 1/4" in my DR 250-s. The expansion of PL would have been more of a problem than a blessing there, I think.himhimself wrote: ↑Mon Aug 20, 2018 2:16 pm I've become a huge fan of PL, using it for lots of other types of projects around the house too. However, I have a question. Is there any downside to using a good wood glue for some of the face to face joints? For instance, the woofer spacer to baffle (assuming no mesh), or some of the places specifying to double up 1/4" ply to give 1/2" thickness. PLs great, but the mess is sometimes annoying.
For braces and panel joints, PL Premium (or something equivalent) is absolutely advised. It's not just about being air tight, it's also about not having voids that can vibrate and cause noise.
In build order:
O12 with no tweeter.
3 x WedgeHorns.
2 x Jack 10 without tweeters.
2 x DR250.
2 x 16" T39
1 x Tuba 24
2 x SLA Pro (sort of...)
3 x WedgeHorns.
2 x DR250.
2 x 16" T39
1 x Tuba 24
