Speaker Stands
mj90210
Speaker Stands
#1 Post by mj90210 »
I have read in old posts that at some point Mr. Fitzmaurice had a set of plans for speaker stands. Does anyone have a picture of them or the plans themselves? I understand there is liability with this subject and if no answer is the best answer, I am fine with that.
Thanks!
2xDR300's
4xDual-30” Tuba 60’s
Simplex 21" Eminence NSW6021
1x20” THT
TLAH‘S
SLA Center-9 driver and Surrounds
SLA pros
TrT 10" Driver-10" Wide
Auto Tuba 10" Driver
J_Dunavin
Re: Speaker Stands
#2 Post by J_Dunavin »
I had also looked for those again at one time, they where like two halfs that slid together.
Re: Speaker Stands
#3 Post by Tom Smit »
I found this quote in the forum (June 2012).
Bill Fitzmaurice wrote: Tue Jun 26, 2012 8:36 pm It was pulled as the stacking brackets in the latest DR revision made it obsolete.
which was in answer to this question...
djtrumptight wrote: Tue Jun 26, 2012 5:29 pm can someone please post a link to Bills information on building stands for tops ? The ones with the trapezoidal shape ? I cant find it,thanks in advance.
Re: Speaker Stands
#4 Post by CoronaOperator »
I remember those, they were just like this table: Scroll down to where it says knock down table:
http://www.handyman.net.au/workbench-inspiration
Now make it taller and triangular so the top is the size of your speaker, but the bottom is wide. Add some cutouts for a ratchet tie down for your speakers, add cutouts to lighten it if that's your thing, then make it look pretty.
Can't see you making them any cheap than real ones though and they are adjustable.
