Driver for SLA Pro
Short and Transmission Line Arrays for Pros
minniew
Driver for SLA Pro
#1 Post by minniew »
Hi.
My large rig 4x T48s and 4 x OT12 is great and I enjoy it very much, it's just a bit on the large side for my smaller gigs.
I am currently in the market for SLA Pros, but being stuck in South Africa, Eminence drivers are somewhat unobtainable.
I know the given driver for the SLAs is the Alpha 6As.
The driver I can source locally with the specs nearest to the Alpha 6 is the FaitalPro 6FE200.
Fs - 120Hz
Qts - 0,62
Xmax - 4,67mm.
Will it be acceptable or shall I keep on searching?
Thanks
Werner
Four 24" T48s 3015LF
Four OT12s (Delta Pro 12)
Busy With:
Four OT12s
Three WH10
Re: Driver for SLA Pro
Close enough.
minniew
#3 Post by minniew »
WOW Great :hyper: :hyper: :hyper:
Thanks Mr. Bill
Busy With:
Four OT12s
Three WH10
djlivex
#4 Post by djlivex »
I've been using my SLA Pro for the last 4 years built like a tank and I use Faital Pro 6FE200 its loud and clear. Need to use a little eq on top end (-). I also have a custom cover for it to prevent from scratching. I have also 4 Tuba 24's loaded with BP102 4 oHm, I only bring in the 4 subs if larger that 300 venue.
