6 Tuba 45s
J_Dunavin
6 Tuba 45s
#1 Post by J_Dunavin »
I'm trying out google pictures to post stuff, since Photo bucket went in the.. well... bucket. :roll:
It's like a fresh piece of canvas, lets make some saw dust :chainsaw:
88h88
Re: 6 Tuba 45s
#2 Post by 88h88 »
I'm seeing a no entry sign where a photo should be. Have you tried putting them on imgur?
bitSmasher
Re: 6 Tuba 45s
#3 Post by bitSmasher »
I'm not sure Google will let you embed pics drectly from Photos, but one thing to double check is if you're using the shareable URL...
otherwise, Tinypic is a handy site for sharing (but not storing) online
J_Dunavin
Re: 6 Tuba 45s
#4 Post by J_Dunavin »
Oh it doesn't work?? I can see it on my main PC and my phones web browser.
Re: 6 Tuba 45s
#5 Post by Tom Smit »
J_Dunavin wrote: Mon Jul 02, 2018 6:26 am Oh it doesn't work?? I can see it on my main PC and my phones web browser.
Try to see it, but not when logged into the forum. I don't see the picture either.
J_Dunavin
Re: 6 Tuba 45s
#6 Post by J_Dunavin »
Ok I'll try another share site.
On a positive note, eminance customer support was kind enough to send a PDF of the basket drawing for the 3012lf. Now I can draw the mounting holes spacing 1:1 in draftsight, print it and drill the mounting holes for the T nuts, without having the actual driver yet.
David Raehn
Re: 6 Tuba 45s
#7 Post by David Raehn »
The driver spec sheet is perfectly accurate for the mounting hole and screws. Lay it out with a compass and a straight-edge... Probably more accurate than printing it out.
BFM rig:
6 OT12
4 T48
4 WH8
Other:
56 box Electrotec LabQ rig
Way too many cables
:noob:
Padde298
Re: 6 Tuba 45s
#8 Post by Padde298 »
J_Dunavin wrote: Mon Jul 02, 2018 12:07 am It's like a fresh piece of canvas, lets make some saw dust :chainsaw:
Loving that feeling... <3<3<3<3
2 x TAT
J_Dunavin
Re: 6 Tuba 45s
#9 Post by J_Dunavin »
I'll try and get more pictures up. Did the 1st one finally work?
Made progress yesterday and got all 90 pieces rough cut... Ugh that's a lot of plywood!
Re: 6 Tuba 45s
#10 Post by Tom Smit »
J_Dunavin wrote: Tue Jul 03, 2018 6:31 am I'll try and get more pictures up. Did the 1st one finally work?
I see a sheet of plywood on a set of saw horses.
J_Dunavin
Re: 6 Tuba 45s
#11 Post by J_Dunavin »
This isn't the whole pile, but most of the pieces for the T45s
commander_dan
Re: 6 Tuba 45s
#12 Post by commander_dan »
Heh looks similar to the pile of panels I had when building my 6 T30s. Looking good so far 👍👍👍
6 T30 (24", 3012LF)
2 OT12 (MA, 3012HO)
2 T24 (18", 3010LF)
Running:
DCX2496
XTi 2002
XTi 4002
TRAKTOR Z2
TECHNICS 1210 Mk5's
Re: 6 Tuba 45s
#13 Post by Chris_Allen »
I can't even stack wood that tidily.
J_Dunavin
Re: 6 Tuba 45s
#14 Post by J_Dunavin »
:D
Ha! Normally I'm that organized either, but with trying to build DRs and a bunch of Tubas all under a time line, I'm really trying to stream line the process.
At this rate I'm going to have to have a painting party the week before the gig. Invite a bunch of guys over, get some pizza and drinks and roll some black paint.
J_Dunavin
Re: 6 Tuba 45s
#15 Post by J_Dunavin »
In an effort to save time I drew the path in Draftsight and had office Max print a 1:1 copy. I cut out the important stuff and carefully lined it up on the ply wood. Then marked the plywood, took a rule and connected the dots.
I did double check the print 1st against the dimensions from the plans as well as checking some major points on the wood afterwards.
It REALLY speeds up the process and for me seems more consistent.
Not shown, but I also flipped it over and drew a line down the middle of the path, so I can easily shoot my Brad nailer on the backside, and know where the piece is.
