Start with some posterboard. Nice and cheap. Cut it/splice it to end up with the size you need. Masking tape works fine for the splices, tape both sides. You want to end up with the exact dimensions of the panel you're laying out. Once it's to size, do a dead-accurate layout on one side of the template, then use a razor or utility knife to cut out just the ends of each run. Make sure the cuts are accurate! Mark the template as sides 1 and 2, or right and left, or some way to remind yourself. This is a T39:
Once all the ends are cut lay the template on the panel, exactly flush with all sides. Tape it in place if you wish. Now, trace out all the cuts in the template to the panel:
When that's done, remove the template and play a game of connect the dots with your straight edge:
IMPORTANT! After you've completed this step, repeat it on the second side panel with the template flipped over! (Side 1 and side 2)
When you're done, you'll have two perfectly identical sides in mirror image, ready for drilling and assembly!
[/img]
