Is anyone familiar with this issue ?
djtrumptight
#1 Post by djtrumptight »
Amp is QSC GX7,2 T48's on each channel for a 4 ohm load.I recently did a rental and after getting everything up and running i noticed my bass was low and 1 channel on my amp was clipping which has become a signal to me that something is wrong with 1 of my woofers.If i unplug the problem speaker the bass becomes louder on that channel,connecting the speaker back is like reversing the polarity on one and seems to cancel out the other.As of right now my plan is to send it out to be reconed.Touching on various parts of it makes it louder.I have had problems with the leads going to the speaker jacks on this woofer and i soldered it back.
https://www.youtube.com/watch?v=N6U_Rvi ... e=youtu.be
2 Autotuba's MCM 55 2421
8 T48's 24"wide 3015 LF
2 SLA HT systems
1 Table Tuba Dayton DCS 255-4
2 T 39's 20" wide 3012 LF
1 T-18 13" wide MCM 55 2421
2 SLA Pro's
Re: Is anyone familiar with this issue ?
#2 Post by Bruce Weldy »
video doesn't work
#3 Post by Tom Smit »
Bruce Weldy wrote:video doesn't work
....because it hasn't been made public yet (ie, still private).
djtrumptight
#4 Post by djtrumptight »
Sorry fellas,the video has now been made public.
2 SLA HT systems
2 SLA Pro's
#5 Post by Tom Smit »
Vid is working. :clap:
Wow, that's weird... that it gets louder regardless of where you touch. Does the problem follow the driver, and not bound to one channel? I''m pretty sure that you indicated that but I'm simply looking for clarity. :)
#6 Post by Bill Fitzmaurice »
That's strange, it looks more like an amp fault than a driver fault.
djamps
#7 Post by djamps »
I agree it looks like an amp or wiring issue
At least check the speaker with an ohm meter between terminals and from each terminal to the basket, then also test the wiring and connectors.
djtrumptight
#8 Post by djtrumptight »
I did check the amp channels at the event,switched the speaker wires,other set of T48's worked fine on that same channel.In the demonstration video i posted the driver was connected to a computer speaker system while a 60 hz signal was playing thru Audacity.This the driver i had a problem with before because of a broken tinsel lead wire.I think i will just have it reconed,aside from this driver i have 3 blown 3015lf's and i built 4 more T48's last summer that i never put drivers in and i plan to use all 8 of them for an event coming in August so i guess the time is now.Thanks for the input.
2 SLA HT systems
2 SLA Pro's
