Yamaha M-85
y2kindyz
Yamaha M-85
#1 Post by y2kindyz »
Hey guys I have an old amp Yamaha M-85.Image
It has 3 pairs R/L channels. Does this have any potential in HT use? Or is it better suited for zone usage or garage duty?
Thanks
Re: Yamaha M-85
#2 Post by Bruce Weldy »
Stereo doesn't cut it for HT.....so, it's off the to garage or some other area where you listen in stereo.
Re: Yamaha M-85
#3 Post by Bill Fitzmaurice »
Bruce Weldy wrote:Stereo doesn't cut it for HT...
I'd use it with dual subs, or just one channel
if I only had one sub, bird in the hand that it is.
y2kindyz
Re: Yamaha M-85
#4 Post by y2kindyz »
Great thanks Bill and Bruce.
One more question:
I also have a Denon POA-5200 amp.
Image.
If I were to build a LPTHT with the Dayton Audio DVC385-88 15" DVC Series Subwoofer which Amp would be the choice?
Thanks again,
Oscar
Re: Yamaha M-85
#5 Post by Bill Fitzmaurice »
Look at the ampere current draw on the back panels. Whichever is the higher probably has the most rubust power supply. The Denon says 4.7 amp on the spec sheet.
