doubling amp resistance
Rich4349
#1 Post by Rich4349 »
If an amp is rated for 2,4, and 8 ohms, will you harm it by running it at 16? Or running a 4 ohm amp at 8?
dswpro
Re: doubling amp resistance
#2 Post by dswpro »
Running a higher impedance should not be a problem. There could be exceptions and I wasn't around during the hey day of large tube amps but a higher impedance load is usually OK. If you think about it, an open connector ( no load) has an extremely high (near infinite) impedance while a dead short has a zero impedance. Dead shorts and really low impedance loads cause more current to flow and can burn out parts or if you are lucky, only cause an amp to go into "protect" mode.
#3 Post by CoronaOperator »
Tube amps are picky on the impedance. Solid state amps, the higher the impedance the happier they are, just don't go below the minimum or else they will overheat/over current and thermal out.
