Tuba 24 30" wide
travisb85234
Tuba 24 30" wide
#1 Post by travisb85234 »
Finished my two Tuba 24's. Testing them at 31 volts and they sound great. See my video: https://youtu.be/7KH4iCOKNl8
Re: Tuba 24 30" wide
#2 Post by DJPhatman »
Travis, welcome to the forum! :hyper:
If I may ask, what drivers and how many per cab? How are the wired?
Not too shabby on the build. What plywood did you build them out of? What is the finish? More details, please! :cowboy: :twisted:
travisb85234
#3 Post by travisb85234 »
DJPhatman wrote:Travis, welcome to the forum! :hyper:
There are two kappa pro 10lf per cab. Built with 1/2 inch Baltic birch with duratex finish. Purchased most of the supplies from Leland at speaker hardware. There are two drivers per channel at 4ohm running on a crown xls2500. Crossover is a driverack pa2 at 45htz low pass and 80htz hi pass.
#4 Post by DJPhatman »
SCHWEET!!!
Will you be getting them out to "stretch their legs" (gig) anytime soon? Curious, why do you cross over to the tops so low?
#5 Post by Bruce Weldy »
travisb85234 wrote:Crossover is a driverack pa2 at 45htz low pass and 80htz hi pass.
I hope that's a 45hz high pass and 80hz low pass.
#6 Post by Bruce Weldy »
travisb85234 wrote:Finished my two Tuba 24's. Testing them at 31 volts and they sound great. See my video: https://youtu.be/7KH4iCOKNl8
It's awfully dangerous having the volume on the sub amp anywhere but all the way up. Your limiter won't do any good if someone comes up and dimes the volume knobs.
travisb85234
#7 Post by travisb85234 »
Oh ya thanks, guess it shows I'm a newbie
travisb85234
#8 Post by travisb85234 »
Good point, right now I just have it in my garage and I'm the only one that messes with it but you never know. How do you adjust your input signal so your volume on the amp is all the way up?
travisb85234
#9 Post by travisb85234 »
DJPhatman wrote:SCHWEET!!!
Haha I just built these to have nice sound in my garage but I had no idea how loud they would get. I might take them camping at the lake this summer.
I'm still a rookie so I still have a lot to learn. Where should I set it? 100htz?
#10 Post by Bruce Weldy »
Simple....just turn the knobs all the way up. That's your starting point, then go back through and re-set you limiter.
#11 Post by Radian »
:clap: 8)
