Intend to use two channels driving 2 x Cabs each.
It's a starter for a larger array but want to run an amp for 4 cabs with a little bit of headroom.
My feeling is 150W rms per channel, each cab wired in series and then parallel with its partner.
No EQ, the EQ from the mixer will be sufficient.
Sub amp will be seperate, various combinations are suitable as per Bill's recommendations.
I haven't bought the plans as yet.
Hurry please the amps I am building at the moment.......
What do the guys suggest?
