Behringer
Behringer
Am I the only one who's noticed the recurring theme in subwoofer threads about some lack or another, and the common point is Behringer? I know I personally have swapped out Behringers for Ashly's (full disclosure, I sell Ashly) that are rated lower power and the difference is substantial, pun intended. I don't have much experience with any of the other brands of switching amplifiers. Anybody else?
- Chris_Allen
Re: Behringer
I swapped from Crown xti's to Behringer INukes. The Crowns were too noisy.
I swapped the Behringer DEQ and DCX for a DBX PA2, although the DBX appears quieter, it is nowhere near as flexible in channel routings. At 4 times the price of the DBX, the protea was far too expensive.
Re: Behringer
I've noticed it too Leland.
Quite apart from the issue of their seemingly inflated specs, voltage is voltage.
If an amp has the required voltage swing, it should do the job, right?
Given some people have measured voltage, and seem fine with what they are getting in both voltage and SPL (CO springs to mind with his T60's), I wonder if the "issue" lies elsewhere.
I'll be keeping a close eye on what Bruce has to say with his monitor mixes with his new amp...
Re: Behringer
That depends on how long it can maintain that voltage. Instantaneous/burst power doesn't matter. Long term sustained power does.Grant Bunter wrote: If an amp has the required voltage swing, it should do the job, right?
- BrentEvans
Re: Behringer
Behringer amps are rated in Behringer watts. One behringer watt = 0.6224 QSC watts. Or something like that.
I have used all of the current lightweight offerings from behringer, qsc, crown, and peavey. The peaveys (and presumably the crests) are the best imho. None of them are quite as good as a class AB amp at maintaining rated power output. The behringers perform well enough unless loaded to 2 ohms and/or pushed hard to the limit. Think of them as light duty.
Re: Behringer
That's why I took a chance with one on monitors. Through two shows, they seem ok....but then, I'm not the one listening to 'em......BrentEvans wrote: Think of them as light duty.
While it did put out the listed voltage, it was only by driving it into the red on the input side. Bringing it out of the red reduce the voltage from 60 to 42.
Re: Behringer
BrentEvans wrote:Behringer amps are rated in Behringer watts. One behringer watt = 0.6224 QSC watts. Or something like that.
Re: Behringer
IDK, Crown Macrotech 2400's only put out their rated power on a 15 amp circuit for about 12 minutes, then the whole room goes dark!BrentEvans wrote: None of them are quite as good as a class AB amp at maintaining rated power output.
- Charles Jenkinson
Re: Behringer
Is this official? I'm a bit of a sucker for jokes, but Bruce's 42/60 = 0.7BrentEvans wrote:Behringer amps are rated in Behringer watts. One behringer watt = 0.6224 QSC watts. Or something like that.
Perhaps an email to Behringer technical help may get to the bottom of it....
2xT30
2xT30
Re: Behringer
Re: Behringer
I bought a inuke3k to replace my Crest LT1000 (280w into 8ohm). Tested it indoors back to back, sounded good. I ran it for a weekend gig on generator, and it just couldn't keep up, so I sent it back.
Now I'm running primarily on a QSC GX7. No issues.
I have been running my church's Wedgehorn 6's on a iNuke1kDSP for probably close to two years now with no problems.
Re: Behringer
inukes and generators are a no go.NukePooch wrote: I ran it for a weekend gig on generator, and it just couldn't keep up, so I sent it back.
The inukes have no power factor correction: none, zero, nada. They take an 80 amp gulp of current, then sit around for awhile, then take another gulp. It may average 6 amps over time but a generator cannot react fast enough for its demands. IMO the inukes are for install only or mobile only if you know you'll have good shore power at all your venues. They are fantastic amps for the money if you know their limitations and don't exceed them, generator power is one of them, even running them on long extension cords could have some serious voltage drop with the high 80 amp gulps.
Last edited by CoronaOperator on Fri Nov 18, 2016 7:00 am, edited 1 time in total.
David Raehn
Re: Behringer
I'm sending a pair of GX7s down to Mexico for missions work. Don't want to take any chances.
I have three NU6000s in my own rack now. Continuing the evaluation.....
BFM rig:
6 OT12
4 T48
4 WH8
Other:
56 box Electrotec LabQ rig
Way too many cables
6 OT12
4 T48
4 WH8
Other:
Way too many cables
- Drey Chennells
Re: Behringer
same for me. used all of the above. Now I use crest as the go to for light amps, they have a bit more capacitance than peavey's and upgraded chassis and parts. I like my switches and pots with a solid actionBrentEvans wrote:I have used all of the current lightweight offerings from behringer, qsc, crown, and peavey. The peaveys (and presumably the crests) are the best imho. None of them are quite as good as a class AB amp at maintaining rated power output. The behringers perform well enough unless loaded to 2 ohms and/or pushed hard to the limit. Think of them as light duty.
InfraCoustik
Consulting/Design/Fabrication
Authorized BF Builder
http://www.infracoustik.com/
info@infracoustik.com
InfraCoustik
- BrentEvans
Re: Behringer
It's official. I said so.Charles Jenkinson wrote:Is this official? I'm a bit of a sucker for jokes, but Bruce's 42/60 = 0.7BrentEvans wrote:Behringer amps are rated in Behringer watts. One behringer watt = 0.6224 QSC watts. Or something like that.
