Easy question, sealing woofer to wood?
djlivex
#1 Post by djlivex »
What are you using for sealing the woofer to baffle without damaging the woofer components? Thanks :)
jimbo7
Re: Easy question, sealing woofer to wood?
#2 Post by jimbo7 »
I believe the people who do use silicone caulk. I tried once on a SLA and it was too messy (and cramped lol).
djlivex
#3 Post by djlivex »
Ok but doesn't the silicone destroy paper from the cone if exposed to the gases it produces while drying? I don't know where I read that , that is why I am asking thanks! :fingers:
#4 Post by Radian »
I've never fully sealed the face of a driver to the baffle, the factory gaskets usually work fine, but I also use a torque driver to ensure everything is clamped evenly during assembly. Not everyone has one of those. :broke:
I've had a split-type gasket leak on me once, and for that I used a few small dabs of Hondabond RTV. Ensuring a full cure before closing things up. Now, if I were going that route, I'd actually try FIPG sealant instead of RTV. Similar, but more tacky and cures to an elastic bead.
For anything else on the cabinet, I bought a roll of 1/16" x 3/4" neoprene tape and haven't looked back since. Works fantastic. Thin enough to seal, without distorting the fit of the parts. Compresses to almost nothing. Even better than the roll of 1/8'' thick stuff I got from Parts Express.
For t-nuts (if going that route) I used to use white glue or a dollop of rubber cement to seal and lock the threads, but since I bought a tube of Hylomar for another job, I prefer that instead.
