12 volt mobile DJ rig 3.0...
RubiconProSound
Location: Pollock Pines CA. (between Lake Tahoe and Sacramento...)
#1 Post by RubiconProSound »
I've been through a number of 12 volt mobile rigs over the years for use in areas with no electrical outlets and this is the latest version I've settled on. I thought I would share for the benefit of those that might be building something similar.
[*]Soundstream Picasso Nano , 4 channel class D amp
[*]Denon MC2000 controller
[*]cheap Lanzar 5 band preamp
[*]Plywood and a couple NL4 connectors
[*]Audio Technica ATW 2000 series wireless mic (when wireless is needed...)
Testing it out on the driveway with a fresh set of SLA's and a pair of T18's.
So far so good. The run time off of a deep cycle battery is more than enough for an evening and the volume is plenty for an outdoor wedding ceremony or a rowdy night around the campfire with the gang. I did a western wedding out under a large oak tree in a cattle pasture with no power nearby and the client was impressed that there were no generators running to ruin the ceremony.
The laptop has a 12 volt charger and the Audio Technica wireless mic was chosen because it runs on 12 volts ("wall wart" transformer is 12 volt...)
Built so far:
Re: 12 volt mobile DJ rig 3.0...
#2 Post by Tom Smit »
Cool!
Welcome back, stranger!
Are those the JVC woofers in the SLAs?
What tweets?
RubiconProSound
#3 Post by RubiconProSound »
yeah... it's been a while. :) I forgot my login password and had to have Bill reset it.
Speakers were cheapies from parts Express: If memory serves correct the mids are JVC, and I can't remember who made the tweets. I do remember that I bought a ton of them, I have enough left over to crank out at least 4 more SLA's...
Built so far:
#4 Post by Tom Smit »
Were the tweets the PE buyout of a case of 200?
Delco.
RubiconProSound
#5 Post by RubiconProSound »
The front:
Back:
And with Serato hooked up:
Last edited by RubiconProSound on Sat Jun 25, 2016 3:25 am, edited 2 times in total.
Built so far:
RubiconProSound
#6 Post by RubiconProSound »
Tom Smit wrote:Were the tweets the PE buyout of a case of 200?
Delco.
Yes... those would be the ones.
Built so far:
#7 Post by LelandCrooks »
I still have a case of those JVC's lying around.
#8 Post by CoronaOperator »
... and I have 2 (thats 48) . Probably a dozen or so loose as well. If you have a master plan for them then they are yours, if not I'll eventually get to them.
#9 Post by Tom Smit »
@RubiconProSound, I have to say, "That's a nice, little, rig!" :clap:
#10 Post by Radian »
Indeed! :clap:
...and welcome back! :cowboy:
LelandCrooks wrote:I still have a case of those JVC's lying around.
Seems we all do... :lol:
#11 Post by Chris_Allen »
Those look like T24's rather than T18's due to the tapered mouth of the horn.
RubiconProSound
#12 Post by RubiconProSound »
Chris_Allen wrote:Those look like T24's rather than T18's due to the tapered mouth of the horn.
Yup... I added the additional flare on purpose to allow me some dead air space for NL4 connectors on the front since I end up pointing them at the wall all the time.
On a side note I've been running the T18's for 8 years now with the same $25 MCM woofers and they're still going strong. They'll be on our 4th of July parade float next Monday along with the 12 volt rig.
Built so far:
RubiconProSound
#13 Post by RubiconProSound »
Radian wrote:Indeed! :clap:
Thanks... I've been lurking, just not posting,. :)
Built so far:
